Hi! I have a problem trying to connect a Advantys OTB 1S0DM9LP to Vijeo Citect through MODBUS RTU.
The register that the OTB works with is 2000 X0-X11 for inputs and 2100 X0-X7 for outputs.
The Citect works with different registers, i think. 30000 for inputs and 40000 for outputs.
The protocol i'm using is the Twido modbus RTU (modbus30). somewhere i saw that modbus30 uses %M and %MW for digital and registers, but how do i change my OTB unit to use %M instead of default registers?
I've tried everything, modbus connection works good when i connect the OTB to the Advantys Config softwere.
Could anybody help me out with the right settings or how to proceed?
Thanks!
calle [at] skepp.com
Thanks!
