from the Help please! department...
S7-200 Wonderware Incontrol via USB PPI cable
Posted by Kevin on 16 November, 2009 - 7:35 am
Hi all,
First post here and I am sitting with a bit of a problem.
I need to program my CPU222 using Wonderware Incontrol.
I only have the USB / PPI Multimaster Cable (6ES7 901-3DB30-0XA0).
So far I have not had much luck doing this as most guides assume you have the ethernet module for the PLC.
Any advice would be greatly appreciated.
Thanks in advance
"Now this is a totally brain damaged algorithm. Gag me with a
smurfette."
-- P. Buhr, Computer Science 354
Advertise here
advertisements
MatrikonOPC has over 500 OPC interfaces and out of the box software. Find an OPC Server for your devices here.
our advertisers
