NIC problem
borzu
I setup two workstations and each one with two NICs with two different IPs and subnets. Both of server and client run at them. When I include both NICs in the server configuration file there is sometimes communication failure. when I remove one of them anything is ok. why?
G
Gerald Beaudoin
Are they both identical...from the same manufacturer?
I have had communication issues in the past that seemed to be resolved by making sure that the 2 NIC's were both the same.
Cheers
Gerald Beaudoin
Jairo Rodriguez
hi there,
could you please run the follow command line for each interface and send me the output :
netstat -nr
netstat -e
they are severals posibilitis : routing problems, phisical damage in NIC, etc
regards,
Jairo
G
Gabriele Corrieri
Hello
> When I include both NICs in the server configuration file there is sometimes communication <
That's get all and nothing, I suggest nothing :)
what server? what is running on this server? Which configuration file? Could you post it here (at least the card configs)
On workstation which software runs as client?
There's active devices (managed switches, routers, gateways ..) between server and clients?
My personal idea it that (apart the different subnets and IP addresses of the NICs) the client, and the server else, are listening and talking on both NICs: windows hasn't efficient way to route requests to a particular NIC, thus there's something like a 'round-robin' to route packets to NICs: probably that the entire application client-server gets in 'loop' between the NICs: you can easily see it because the NICs ACT leds are blinking fast even there's not reason (in other words: when server has configured two NICs the ACT leds are blinking more fast that when is configured only one)
My entire post is written around my personal experience (little) and a (very little) information that you have posted in the thread.
Gabriele
BTW: you can easily contact me by checking over the net my nickname (that's my real name)
