we operate GE 7EA machine in COGEN mode with MARK VI/DLN-1,fuel Natural gas. when we shutdown the machine or reduce load to 30MW the machine trips in "failure to reignite primary zone" (dln trouble trip). we inspected the igniters/cable and restarted it fired very fine then we forced a command to fire at 50MW and at base load to check, but it failed to ignite even though the command initiated and we checked the flame intensity but negative. then we also tried changing the timers yet no affect. we also ensured the orientation of spark plugs as per the manual. still it fires when startup but fails to fire at shutdown-can any body guide us on this?
