G
I’m trying to create a testing environment for temperature and humidity with Labview. My problem is that I can’t communicate with the device which controls parameters. My equipment is the following:
-West 4400 1/4 Din Profile controller
-USB485ui serial adapter from Amplicon
Communication protocol is Modbus RTU. I tried to communicate and to send modbus command with Hyperterminal, Labview VIs (Looppack or Modbus pack) and others softwares but I can’t get any response from the device. Visa detects it on COM port. It seems that the device is connected but I must send bad commands to it. Is there any simple mean to chek that a modbus device is communicating ?
I’m just a beginner in modbus protocol so if someone could give me any help or advice, it would be great.
Thanks.
Thanks.
