we have a drive model 6ES7021-0EP60...and suddenly started tripping on F011 fault. Not able to reset rated current of the motor in 6.4 am and Motor is taking normally 3.4A at full load. Now what is this f011 (says over current)....don't understand how??? Is there any remedy or possibilities which can correct this fault OR replacement which i have already done is the only solution. Kindly help.
Jonathan
Jonathan
