i am unable to reinstall rsview32 version 7.20. The software stops at 54% install saying disk space is full, even when disk is 50gb empty, sometimes it stops at 67%. software is original with license activation
Check the Knowledge Base on the Rockwell Automation site. There is a pile of tech notes regarding issues with install/remove/re-install issues and procedures. You'll probably find what you need there.
Good luck
Cheers
Gerald Beaudoin
Good luck
Cheers
Gerald Beaudoin
An elephant is a mouse with an operating system.
on 10 January, 2011 - 1:11 pm
