Thursday, May 24, 2018
Uploading Program from Quantum PLC
The Quantum PLC was programmed using "Proworks", is it possible to upload the program using "Concept software"?
By yangyang on 10 May, 2011 - 6:54 am
By Brian Cervi on 11 May, 2011 - 8:40 am
Yes, you can include the "Proworx" logic in a Concept project as a non IEC section, 984LL. You should also consider moving to Unity. Unity will import the entire Proworx project and integrate it fully into a powerful and full featured IEC software package. Check with a Schneider sales office or a distributor.
By yangyang on 12 May, 2011 - 5:39 am
---- snip ----
will there be no conflict on the configuration such as tag addresses, Derived Function block (user-defined function block) and etc?
thank you for the additional option (Unity)
By Brian Cervi on 13 May, 2011 - 8:59 am
With the new feature introduced with Unity V5.1, it is possible to open an existing Modsoft, Proworx NxT or ProWorx32 project directly into Unity as another "language" (non IEC).
The conversion works best with projects configured for Quantums but will convert old Modicon 785 style projects. Currently, the result is a Unity Quantum project. There will be a Compact to M340 project conversion later this year.
References (addressed I/O) without a tag (symbol or variable name) will have a tag name constructed out of their address (eg 10001 will become _10001).
Solution of the logic in the new 984LL editor remains as you would expect, solution is column by column and bit type instructions remain, for this editor, in the "old" Modsoft format.
The GUI for this editor has the look and feel of Proworx NxT.
Even nicer, no need to upgrade the controller. The 6th language in Unity (FBD, ST, IL, LD, SFC plus 984LL) is simply compiled and downloaded with the IEC languages. You can mix editors as required (984LL plus FBD plus ST etc). Full online edits remain.
The conversion is amazingly accurate and eliminates the necessity to re-write logic. Save time and money and simply use your old logic.
