What Setpoint I have to use to control 2 rising cylinders? the load on cylinders may vary. always one cylinder will move faster than other, don't know which one.
First case: Cylinder 1 higher than cylinder 2
I want cylinder 2 to move with max possible speed, cylinder 1 to slow down until both are same height.
Second case: Cylinder 2 higher than cylinder 1
I want cylinder 1 to move with max possible speed, cylinder 2 to slow down until both are same height.
Can I take as Setpoint the slowest cylinder height?
When I tried that when they reached same height, they shook, and didn't move smoothly.
or there is other way?
