Dear all,
plz give your comments on following.
Three Alternators sychronised with the grid and off course parallel with each other generating some MW and MVAR. Now suppose we raise the excitation of one of the alternators, its internal voltage will rise but the terminal voltage/grid voltage will remain same if grid voltage is not changing(plz correct me if am wrong).
1) Will internal generated voltage of alternator be same in magnitude to field excitation voltage but opposite in phase or polarity?
2) Practically when the alternator is connected to grid, how we will differentiate between terminal voltage and internal voltage of alternator? At which physical location of the alternator winding this internal voltage will be developed?
3) While three alternators in parallel with the grid are giving different MVARs so will there internal voltage will be different and will there be any circulating current flow between the alternators?
4) What will happen to No. 3 query if the alternators are in parallel but not connected to the grid and we have our own home load.
thanks n regards,
Ashish
thanks n regards,
Ashish
