it is supposed that when one of exhaust thermocouples read a temperature higher or lower than the adjacent ones by some value, the system will exclude this value from estimating the average value that used to control the base load.
lets assume this value is not excluded and say the average exhaust estimated to be 520 instead of 540. what will happen to the base load value and turbine inlet temperature, will the unit run on higher or lower TIT
thanks
thanks
