I have a query regarding Capillary type pressure transmitters installed at our Urea Plant.
There are two transmitters installed at Carbamate service. Their specifications have been listed below:
(1) Transmitter Model:FOXBORO I41GP-ES1D1P3EA4H-A2
Range: 0-200 kg/cm2
WITH SPECIAL SEAL ACCORDING TO SNAMPROGETTI SPEC. GA-E-60221
Seal length: 131 mm
Operating temperature: 220 Celcius (max)
(2) Transmitter Model: 141GP-ES1D1P2FAAF-AM2
Range: 0-200 kg/cm2
WITH SPECIAL SEAL ACCORDING TO SNAMPROGETTI SPEC. GA-E-60223
Seal length: 95 mm
Following are my queries :
1.Which factors determine the seal length of the Transmitters, because the service, pressure range and operating temperature for both of these transmitters are almost same? So why one transmitter has 131 mm seal length and other has 95 mm seal length?
2. What will happen if I install 95mm seal length transmitter at location where 131 mm seal length transmitter is installed and vice versa?
Please reply to these queries as soon as possible.
Thanks and regards,
Range: 0-200 kg/cm2
Seal length: 131 mm
Range: 0-200 kg/cm2
Seal length: 95 mm
Thanks and regards,
