P
Vibration in No-1 bearing increases incessantly above 12 mm/s when the load increase above 25 MW and I don’t know the ending of the increase of vibration as I can’t let the GT to trip. However, we have experienced 14.1 mm/s at 27MW load in 49.5 Hz, whereas, below 23 MW the GT is operating smoothly without any anomaly. Moreover, it has been observed that the vibration in No.-1 bearing is relatively higher when GT is running at low frequency (<50Hz) and other bearing vibrations are more or less same. The table below shows data of vibration at different loading condition-
MW------Hz--------Bearing 1------Bearing 2-----Load Gear-------Generator
-----------------(Comp. side)----(Tur. side)-----Bearing--------Bearing
-----------------BB1-----BB2----BB4----BB5-----BB7----BB8-----BB9
15------49.2----5.1-----5.8-----3.6-----3.7-----0.1-----4.6-----5.8
18.5----49.2----4.5-----4.8-----3.5-----3.6-----0.2-----4.4-----5.9
20.5----49.2----4.8-----5-------3.6-----3.6-----0.2-----4.8-----5.8
22------49.2----5-------5.4-----4.1-----4.2-----0.2-----5.1-----5.8
23------49.2----5.8-----6.2-----4.5-----4.6-----0.2-----5.6-----5.6
23.5----49.2----7.6-----7.3-----5.8-----5.8-----0.2-----6.1-----5.5
24------49.2----8.8-----8-------6.1-----6.2-----0.2-----6.4-----5.5
29------51.1----8.2-----9.3-----5.9-----5.9-----0.4-----8.5-----5.3
The particulars of the GT is simple cycle GE Frame-6, PG 6541B, running on natural gas, base load operation, no steam injection, supply power to 33kV distribution line which is connected to the national grid. Running hours more than 102000 hrs, which was under shutdown for the last 8 months. Before long term shutdown the GT was operated on 32-34 MW and the maximum vibration was below 7 mm/s, moreover, the temperature at different point before and after the maintenance is almost same. The last maintenance activities, within the shutdown period, were- Changing of Inactive thrust bearing, Disassembling and assembling of Compressor upper shell casing (up to 11th stage), Prosthesis in generator stator winding, disassembling and assembling of Rotor, dismantling of retainer ring and wedges, and assembling of those. However, before changing the inactive thrust bearing the axial movement of the prime mover was 0.61 mm, whereas, after changing the thrust bearing it came to 0.42 mm.
Presently the GT is operating on 22-23 MW. Can anyone please suggest us how to find and solve the problem? Please give us some idea about the cause of the problem?
Waiting for your valuable suggestions. Thank you.
