T
I was told that with the increase in the dP across the inlet, the air flow to the compressor reduces. In a CT there is always excess air for combustion, the reduction in air flow does not reduce combustion but reduces the air for cooling which in turn will increase the temperature in the firing chamber and thus the exhaust temperature. was incorrect. Any Help?!?!
