P
I have a fuel tank which is a horizontal cylinder. It's length is 60'' and it's radius is 11'5'' It holds just under 100 gallons.
I would like to use a yardstick as a dipstick. I know inches to gallons may not be accurate in this situation because the tank is not square. I need a formula with the correct constant to be able to graduate my dipstick so as to get correct readings of gallons available.
Thanks in advance.
Thanks in advance.
