R
I am using WW 9.5, opclink 8.0, and trying to read data from Matrikons S7 server (MPI link). I read data ok when using Matrikon simulator but when using live server all tags error out. It appears that the syntax is different in the server as compared to simulator. Simulator syntax is with (.) as delimiter and the live server uses (>) as delimiter. It doesn't look like OPClink is able to understand this syntax. Also I am wondering about the ITEM syntax in the InTouch tag database. I have seen so many different ways recently I have no idea which is correct. Thanking anyone in advance if they can shed some light.
