I
a gas turbine frame5 tripped by high exhaust temperature spread trip after 25MW going to the base load. at 25 MW it is ok. allowable spread and sp1, sp2, sp3 are acceptable. may you know what the problem comes from? if you need more information .pls ask me? thanks.
