P
Can anyone tell me the Heat Load of the turbine compartment for Simple cycle gas fired Frame 6 Gas turbine?
A Frame 6 Gas turbine was running in Helsinki, Finland and now brought to a new place as a second hand turbine where the ambient temperature is 35-36 oC. As the ambient condition changed, therefore, Turbine compartment cooling becomes insufficient. Turbine compartment temperature at the new place is above 70 oC.
Please help me by providing the heat load of that compartment that should be dissipated by the 88 BT fan.
Is there any impact of ambient temperature on Turbine shell cooling? Please also provide the shell cooling load if possible.
Thank you.
Thank you.
