Wednesday, February 21, 2018
MODBUS RTU help needed
PC MODBUS RTU software
By Chris Ferrell on 3 May, 2012 - 12:00 pm
Guys I need help. I'm a HVAC controls contractor and I have a constant issue with MODBUS RTU and my ability to connect to an MODBUS capable device. I want to be able to walk up to a device, (IE Rooftop HVAC unit, Data Center UPS unit) and connect to it with my laptop and see basic things.....It it addressed correctly....is it communicating at all....can I poll a register...Can anyone help with this?
By bob peterson on 3 May, 2012 - 12:51 pm
there are a whole bunch of Modbus master software packages out there.
Bob
Win-tech Modscan32 (run 5 minutes for free)
http://www.win-tech.com/html/modscan32.htm
Simply Modbus
http://www.simplymodbus.ca/
Chipkin Modbus Scanner
http://www.chipkin.com/cas-modbus-scanner
take out any spaces the forum inserts into the URL
By Andrzej on 7 May, 2012 - 6:17 am
You can use the Modbus Tester as the master.
If you want to find the communication setup (slave address, Baud Rate, Registers range, etc.) you can use the Modbus Scanner.
The programs you can download from www.modbus.pl
Andrzej
Thank you guys!
