F
We have governor system consisting of Pressure tank, servomotor, distribution valve etc.
Our unit always sticks when a raise from 230MW to 290MW is given. After initial start the behaviour absolutely normal, but after 3-4 hrs of operation at 230MW when we try to increase load it sticks. We have seen at governor pressure system that control system raises the distribution valve fully open. As we have thoroughly checked the control system and found its behaviour completely normal. We have changed the distribution valve with new one, but no effect at all.
what do you thinks where the problem lies?
