We are upgrading our pneumatic air isolation procedures. We have over 200 valves in a plant which are pneumatically driven. The solenoid for these valves are located in the head of the valve. We feed these valves from a mains air header and tap off to each valve with a 6mm supply. Where each valve is connected in to the mains header we have a non-return valve. We now need to be able to isolate the 6mm airline before it feeds into the valve and lock the supply off. The idea to do this would be using a miniature ball valve which is lockable and which also vents off when isolated which releases any air to the valve. Does such an item exists?? I know you can get an inline ball valve which can be 6mm airline in and out but I can't seem to locate any which are lockable.
