I was looking for the Digital signal cables used to connect the transmitter in field to DCS and vice versa. Normally a 1-5v DC is used as signal. what will be the Wire gauge required? which are the common makes available?
I have used Dekoron (Brand) cables for the instruments at my Power Station. Using 1.5mm2 for a single pair and 0.5 mm2 for multicore cables. Also for the analogue signals using individual&overall screen cables and for the digitals using overall screen cables.
