R
Hey guys, I am looking for a solution and running against walls since weeks...
I have to connect a meteorological station with ABB microSCADA (Sys600) as part of a student project at my university.
The met. Station is sending every 10 seconds a data package
(<stx><lf>yymmddhhmmss;<sp><sp><sp>[measurand1];<sp><sp><sp>[measurand2];<sp><sp> <sp>[measurandn];<sp><e tx>[bcc1][bcc2][bcc3]<cr>)
via RS232 to the SCADA-Server. The problem is, I cannot find a system object where I can specify the input stream (byte-position of measurands or measurand separators or whatever). I've found the line object "SPA" that uses the RS232 interface (COM port, baud rate, etc), but I have no idea how I should specify the incoming data packages. It seems, there no one-way communication designed for.
Know I think, I have to convert the data packages into something useful for SCADA (i.e. MODBUS), but I can't find an easy-to-use tool to do this.
Hope you can help.
Thanks a lot for support!!
Robert
Hope you can help.
Robert
