T
my new project need to get data from GE power meter EPM5500P, which support Modbus RTU protocol. Our PLC is Schneider Quantum PLC (CPU-651, or CPU-434), and connect with SCADA WinCC via Modbus TCP/IP.
- I have try to connect EPM5500P and Quantum PLC by using some Modbus function block in library and Modbus plus port on PLC (I use Unity Pro for programing), but not success. Anyone have experience about this can help me? I'm don't have many experience about Modbus.
- I also have a GE Multinet module which is converter Modbus RTU to Modbus TCP/IP. Can I connect Power meter to this converter, then connect to WinCC, so I can read data from power meter? Or other solution (via OPC,...)?
