from the pvbrowser department...
Accessing memory using rlmodbus daemon
Communications systems and equipment. topic
Posted by Diego on 24 May, 2012 - 10:38 am
How do I access all memory of the Schneider-Electric PLC Premium? I can only read up to the %MW1024 memory location using the rlmodbus daemon (rllib library).
Posted by pvbrowser on 30 June, 2012 - 11:12 am
You will have to look into the documentation of the Schneider-Electric PLC. There you should find a table with the Modbus mapping of your PLC.
rllib will simply request data from the PLC under an address you specify. Since Modbus uses 16 Bit addresses the address range is from 0 to 65536.
If the slave device (here your PLC) has data in the specified location it will respond with the according data.
But if you use an address that is not listed in the Modbus mapping of the hardware vendor the slave device will respond with an error telegram meaning that there is no data available on that address.
There may be several address ranges within one device. Normally 1 for coils and one for registers.
Mitchell's Law of Committees:
Any simple problem can be made insoluble if enough meetings are
held to discuss it.
Advertise here
advertisements
our advertisers
