E
hi all,
consider the situation, you have a 60hp motor running with a vfd. you get starting problem. vfd is ok. you suspect the motor.
resistance/lamp test gives ok. now you want to run the motor without vfd for testing.
now, (this is the demand of the question) you can run it on either star or delta, no star delta. and you can run it only once (for testing).
which connection will you choose and why?
