P
Good day;
I am attempting to install a Syemmetricom BC620AT for time sync in a Mark 5 <I>. I have powered the system down and installed the card with base address and IRQ configured as outlined in the TIMESYNC.DAT file. The <I> boots up with no arc net communication. I power down and remove the Syemmetricom card and power back up. On reboot the arcnet driver does not load and when <I> is back running still no ARC Net communications. I power back down and replace Arcnet card with a known working spare (same model ARC NET card cnet 90C98). I leave the Symmetricom out and power back up.The eye comes on line working fine good comm and all. It is almost acts like the ARCNET card and Symmetricom card were are trying to use the same resources. If there is anyone who has configured this card to work on an <I> could you please share your base address and jumper settings I believe that this is where my problem is.
PK
PK
