W
I am trying to connect a Ge 90-30 cpu 363 to a Beijer Qterm A12 HMI over Modbus rtu. The cpu is slave and HMI runs a Movicon CE master rtu driver. Communication fails and HMI displays slave's timeout error. I use a Ge rs232 to rs485 cable adapter for connection from rs485 port on CPU to com1(rs232) on HMI.
Settings: 19200, 8 bits, Even parity, 1 Stop, No flow control. Any suggestion on cable,or port setting would be appreciated.
