With much fear and trembling, frustration and embarrassment, why have I gone through 3 Atomizing Air Compressors in less than 3 months?
Unit 7EA – Non DLN – Distillate – Water, Liquid Fuel, Atomizing Air Only.
What am I doing wrong?
What am I not seeing?
What have I not considered?
1. Physically all piping has been dismantled and checked for clogging – nothing there.
2. Borescope all piping and areas that can’t be physically seen – nothing there.
3. Valve V-18 – Borescoped in operation to check positioning – default position – open at all times – solenoid de-energized – everything ok.
4. Valve V-22 – Borescoped in operation to check positioning – closed position when energized solenoid – open position when de-energized solenoid – everything ok.
5. Check Valve – removed and inspected – ok.
6. Pre-Cooler Borescoped and Inspected – ok.
7. DCS Comparative Condition Studies – Blower, Atomizing Air Compressor, Turbine Compressor behavior – before failure to AA Comp – all seem normal.
