i have 120 remax grounded wire. says 600volts on the wire, running about 60 feet. i want to run 22 awg wire 300V near it. about 15 feet of it. the 120 is not in conduit so how far away should the 22 awg 300 v wire be from the 120 remax wire?
D | 120/277V Power Connect for Hot Water Tank | General Automation Chat | 3 | |
K | Not Able to Configure ABB DMC tzidc 120 | General Communications Chat | 0 | |
P | Transferring Parameters from BOSCH 120 | Computing | 1 | |
A | 120 MW Thyripol excitation system | Power Generation | 1 | |
S | Modbus Error: Bad checksum on code 120 | Modbus | 0 |
