According to PCV installed here its datasheets show a range value of min to max flow with correspnding vlaue of precentage valve opening. So, there would not be any flow through PCV when The min valve position and corresponding flow is there. e.g. Min Flow in 70TPH and % valve Opening is 26%. When PCV is less than 26% then there would not be any flow?
