I was trying to do file transfer from one Mark V gateway computer through fastlink. It is unable to copy this file:
idp\config\unit1\eprom.
The GEDS Standard Message (GSM) gateway enables the distributed control system (DCS) to communicate with the Mark V turbine controls. I had a hard disk on a mark v gateway computer on our gas turbine arcnet network which got corrupted. I installed a dos 6.22 floppy diskets 1, 2 and 3 on a new hard disk. I was then trying to do file transfer from one Mark V gateway computer through fastlink to the new computer, that is from a host computer to a remote computer. The host computer sends the file directory idp\config\unit1\eprom to the remote computer but the remote computer is unable to copy idp\config\unit1\eprom directory. The process then stalls. When I restart the remote computer, it is not able to boot. It tells you "starting MS-DOS" and noting happens indefinitely.
What must i do to copy this file into the remote computer since I do not have the software to restore the gateway?
E-Mail: [email protected]; [email protected]
