P
Hi all,
I need to ask some experts advice. I am looking for a Power Meter for Single Phase 13Amp with Ethernet connectivity for Monitoring and Digital or Analogue Outputs.
Cost is also a consideration. basic power usage real time is all that's required, with some form of output controllable over ethernet. this I will use to cycle the power during the UUT's test cycle.
Has anyone come across such a device? I see there are solutions out there however I find that they are a lot more sophisticated than the solution requires and the cost per unit is very high.
The unit will be monitoring a burn in stress test system. the system will be extendable ie 6, 9 or 12 stages the front end will be developed in visual studio.
Any advice is very welcome, as my head is swimming in datasheets at the moment...
Very best regards
Phezo
Very best regards
Phezo
