I am looking to build a small, 25kW, hydro generator and need help understanding the electrical part of the installation. I want to use an induction motor as the generator. This is to be a grid tied system. The grid at this location is single phase.
If I understand correctly, this can be done so that in the event of power outage, the generator will automatically stop generating. Is this true? Islanding is not allowed. Will any dump load be required?
If power goes down I can figure out how to shut down the turbine. Restarting it would be a manual process. Syncing to the grid becomes a question, one that freaks out any electrical person I have talked with, most swearing that it will take elaborate, expensive equipment to accomplish. IF this is the case, my plan to restart the generator would involve starting it as a motor (no water flowing yet) and once it is up to speed opening the jets on the turbine to push current the other direction. This process should sync the system to the grid, right? Will the generator/motor act as governor for the system?
Motors large enough to use as the generator (30 or 40 hp) are invariably 3 phase but I only have single phase on the grid. I need an efficient way to change the 3 phase output of my generator to the single phase on the grid. How can this be done?
Lastly, if I have ~25kW of mechanical energy on the turbine, how big of a motor should I be looking for.
Finding a competent EE for this job has been a chore and one not completed to satisfaction. The power company isn’t much help either. Any recommendations for consultants? Just FYI, I am an ME by trade.
