we have a bus CS275 redundant(A y B) and one bus(A) no is in software BANY and no have alarms of the BUS, only the alarm when the fault was present. we do reset the UI´s of that BUS A and no reflex anything, check the other connection´s bus with the PG 750 and no is abnormal thing´s, actual is in progress migration the system TELEPERM ME to SSPA T3000 and was installed a CM104 for communication with that system,
We know how [to] config that SIEMENS´s and we feel is incorrect o like some one. the load bus messure with program BANY is normal(53%), no alarm message´s in BANY only the BUS A is desapareced
so some body have a tip?
