We are recomissioning liquid fuel after years out of service. The site has a single shaft 9FA. We can move the LF by pass valve,there are no LVDTs. Two simple questions:
1.- Can we move the valve to percentages somehow simulating flow? When we move it saturates fully open.We move it forcing the output in the MkVI.The valve has a pointer so you can easily see its position.
2.- Would you recommend dry fire? I thought about firing and looking for leaks at firing speed and after if all stable check at FSNL and at different loads.
This post could be a good one for CSA.
Thanks.
Regards.
Thanks.
Regards.
