When a Profibus DP device loses power, the communication to the rest of the DP devices attached on the bus system will fail.
True of False?
I assume the answer is false, since I know that the physical layer is RS485 which is usually configured as star, daisy chain, or T drops. Since Profibus is DP each device will have its own power source seperated from communications line, so that if one device power is turned off the bus still has a communications line connected.
Thank you.
True of False?
Thank you.
