H
We plan to fill our recycle process water tank from three of our process machine overflow tanks. We don't require tight level control or flow split.
I was planning to wire an analog output in series with 3 I/P's and then send the pneumatic air signals out to the valve positioners on each machine.
When I reviewed the specs for the I/P and the positioners, it looks like a single I/P is more than adequate to handle the signal air flow requirement to all 3 positioners. Now I'm thinking that I will connect the pneumatic tubing for all 3 valve poitioners to a single I/P.
Does anyone have a previous bad experience or see any pitfalls with paralleling the 3 positioners.
