Hi 9FA users.
Gas leak test B failure, I have doubt on Gas leak test sequence in frame 9FA DLN 2.6+.
After SRV opens for 1 sec to trap gas pressure in P2 cavity maximum pressure in the P2 cavity is latched, and the latched value is reduced by 150psi, and a logic is generated V86GLTB which is the reference for comparing the value with FPG2 in GT block. THIS FUNCTION TESTS THE LEAK OF GCVs or SRV??
If FPG2 > V86GLTB then it is testing SRV passing, can any explain this in detail to understand easily.
