Z
Problems establishing communication between AB micrologix 1400 and RSlogix 500 to SMC EX260 or EX600 with Ethernet\IP module.
I connected the EX260 Valve manifold to the Contrologix with RSlogix 5000 and it works with NO problems, but when i want to work with Micrologix the problem is that i can't use a hardware configuration with a generic module but i have to use inside the program a message. is anyone have an example how to do it? it will be perfect if someone can also explain how it works and if it can work with SMC valve manifold type EX260 or EX600.
Thank you,
Ziv
[email protected]
Thank you,
Ziv
[email protected]
