R
Hi guys,
We have two Frame 9E gas turbines namely GT1 and GT2. As you can see in the attached data (plant data jpeg file), the heat rate for GT2 is higher than GT1. Compressor in GT2 is replaced early 2012 with honey comb brush seals at the inner barrel. The CPD achieved after the compressor replacement is 11bars compared to 10.3bars previously.
My question is, what can cause the gas consumption to be higher? Both GTs have same control settings. Is tuning necessary after the Major Overhaul works? We suspect that the turbine is working harder to drive the compressor due to the honey comb brush seals. I appreciate any information or guidance given. I am willing to provide all the data required.
Design Data: https://docs.google.com/open?id=0B9IltUsseK6LbEk5dk9vUW14NVU
Plant Data: https://docs.google.com
/open?id=0B9IltUsseK6LR0NKQlFtSDhxTFk
