We have a Frame 6 GT driving our generator. I have always noticed that during auto synchronization the slip frequency seemed pretty fast. This is my first experience with generators so I have relied on the TA for information and was told that looked normal to him. We recently upgraded our protective relaying on our generator panel utilizing a SEL-700G. We hired the relay manufacturer to translate the mechanical relay settings into the microprocessor relay. I then looked over the translation to see if it "made sense" with my limited knowledge of generator relaying. One item that stood out was the slip frequency limit was specified at 0.067 Hz (per IEEE) compared to the 0.25 Hz of my original relay. When we started up the relay wouldn't sync so our electrical engineer had me change it to 0.25 hz and we were then able to sync as before. Now it is a couple of years later and I was looking into the synchronizing control in the logic and I have found that it appears to calculate the generator frequency based on the turbine speed. The logic lists 100% speed as 5105 and elsewhere in our documentation I find that the gearbox ratio is listed as 5106 to 3600. Our actual nameplate ratio is 5094 to 3600. Which explains why we always run 99.8% speed. This seems to me would explain why our slip frequency seems high since generator is being spinning faster that the controls think it is. Based on the fact that the TA stated that the slip speed looked normal to him, is this a common set up or is something wrong here. I think the control should be reset so that 100% is 5094. The system was originally controlled by a Mark IV and is now controlled by a Mark VI. I checked the old parameter documentation and it has been running this way for 20 years. I can't believe that no one has questioned this before if it is wrong.
Can anyone provide some input?
Thanks in Advance.
Thanks in Advance.
