I have a question regarding the isochronous load sharing operation of synchronous generators. I very much appreciate your comments and feedback.
Assume we have three generators with the rated powers of Pmax1, Pmax2 and Pmax3. We want to operate these units in an islanded system in isochronous load sharing mode. In order to preclude fighting between them, we take their corresponding speed settings through load sharing line, we develop an average speed setting and use it as the new speed setpoint for all three generators. In this case, the generators simultaneously go up and down in response to any changes in demand to achieve a fixed frequency in the islanded system. I think this is more or less the mechanism of isochronous load sharing operation. My question is about the relation between loading powers on these units? Somewhere I read that in this mode, each unit shares the demand with the ratio of its rated power to the rated powers of all generators; is this correct and why? For example, if P1, P2 and P3 are the loadings on these three units, what would be the relation between P1, P2, P3 and their rated values? Is the following relation correct?
P1/(P1+P2+P3) = Pmax1/(Pmax1+Pmax2+Pmax3)
Many thanks in advance. I also appreciate any other comments/clarification regarding the general concept of isochronous load sharing mode.
