I can't get the valve to port oil to either end of my hydraulic cylinder.
It's a new valve. I've hooked the two coils in parallel and applied +/- 50 mA (its rating). I've got terminal A hooked to terminal C and terminal B hooked to terminal D.
The plumbing is correct to the manifold that the valve mounts to - I hooked a manual hand valve to the manifold and was able to get the hydraulic actuator to move in both directions.
Seems so simple but I'm at a loss as to what to try next. Any suggestions?
