Hello friends;
I want to calculate the Shaft horse power of the gas turbine. The Turbine is two shaft. The power turbine connected to the gear box and gear box connected to the dynmometer. At dyno the load cell is attached which gives me a Torque in Lb-ft.
So Raw HP = torque*RPM (Dyno) divided by 5252.1
How i calculate the SHP at Power turbine?
