R
Hi all
I need to repair a servomotor and wanted to know all precautions to avoid damage to the engine when disassembling the mechanisms
Also wanted to know if need to synchronize the encoder or resolver when reassembling the engine. i.e. if the encoder has a unique position on the motor axis, if I had to I could do manually synchronize or special equipment is required
Thank you very much for any information
Best Regards
Best Regards
