F
One of the GE 6FA+e gas turbines has a problem of combustion humming caused by fuel pressure fluctuations during start up and unit trips from exhaust over temperature or sometimes flame out.Sometimes the fluctuations of fuel pressure are lower and unit reaches full speed no load without any problem.
we reduced the sensitivity of the fuel control servo valve from 2.7 to 1.95 and was ok for one start, but after a second start next day the same occurred with lower pressure fluctuations and without tripping of the unit.
Fuel and air filters are new. We've checked the IGVs and are constant, also the atomising air pressure is constant.
Any ideas? would it be a problem with the hydraulic fuel control valve?
frixos
frixos
