SCR current draw
DEC
I have 3 banks of IR heaters. each bank is wired with one phase of the 480 supply or 277vac and to neutral. I want to control these heaters with a 3 phase SCR. My question is how do I find the current draw on the inlet side of the SCR? The total KW is 69KW, 23KW each leg. Since the heaters are using 277vac I can find that easy enough 23kw/277vac = 83A since the heaters are tied to the neutral. But on the inlet side of the SCR it is 480vac. I'm not sure how to calculate current draw.
It's the same. Let's say you treat it as a single 480V load. Then
I = 69000 / 480 / sqrt(3) = 83A per phase
