Can anyone help I want to fix a led. into the charging circuit of my battery operated screw driver. The charging system is only 3.5 V. I want to see if the charging system is working at a glance, the led is red and do I to fit a resistor in the circuit and if so what rating ? Also should the led be connected in series or in parallel.
thanks,
mike. [email protected]
thanks,
