N
I have a motor which will be driven from an inverter. the motor is rated for 460V, 3ph, 60Hz and the supply voltage is 480V, 3ph, 60Hz. I would like to know how to size the cable going from the motor to the inverter.
the full load current is 12.5A
the full load power factor is 0.82
it will be routed in conduit
the inverter will be roughly 30m from the motor
